PROBLEM
Unable to configure data store in ArcGIS Data Store
First Published: August 14, 2025
Last Published: October 7, 2025
When attempting to unregister, re-register, or perform both actions on a data store in an existing deployment, the following error messages are returned:
Error:
Attempt to configure data store failed. Caused by: Cannot invoke "com.esri.arcgis.datastore.model.cachestore.CacheStoreConfiguration.getDatastoreName()" because "" is null
Error:
Attempt to configure data store failed. Caused by: Failed to register relational data store. Caused by: Machine '<adminURL> [<machineURL>]' returned an error. 'Error registering item. Registration of database '/enterpriseDatabases/AGSDataStore_ds_' is incomplete. Failed to get connection string from System/PublishingTools GP service.'
Cause
The data store configuration files are incomplete or corrupted, causing the getDatastoreName() method to be invoked on a CacheStoreConfiguration object with a null value, indicating that either the configuration object or its datastoreName property is missing.
Solution or Workaround
To resolve the issue, run a repair on ArcGIS Data Store and unregister or reregister the affected relational data stores. Refer to How To: Restore ArcGIS Data Store for more information.
Article ID: 000037618
Software:
  • ArcGIS Data Store
  • Portal for ArcGIS
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
