PROBLEM
Unable to configure a federated Portal for ArcGIS with ArcGIS Web Adaptor (IIS)
Last Published: October 19, 2023
Attempts to configure the Portal for ArcGIS with ArcGIS Web Adaptor (IIS) in an ArcGIS Enterprise deployment fail, and the following error message is returned on the Web Adaptor configuration page. This issue occurs even though the correct fully qualified domain name (FQDN) and primary site administrator credentials are used.
Error:
Failed to get machines from server site.
The error message returned on the ArcGIS Web Adaptor configuration page
Cause
The ArcGIS Enterprise deployment is in read-only mode. Read-only mode freezes the ArcGIS Enterprise deployment and restricts modifications and operations for the portal, federated ArcGIS Server sites, and ArcGIS Data Store. Refer to Portal for ArcGIS: Functionality restrictions in read-only mode for more information.
Solution or Workaround
Place ArcGIS Enterprise out of read-only mode before configuring Portal for ArcGIS with ArcGIS Web Adaptor (IIS). Refer to Portal for ArcGIS: Place ArcGIS Enterprise in read-only mode for instructions.
Article ID: 000031333
Software:
  • Portal for ArcGIS
  • ArcGIS Enterprise 10 9 x
  • ArcGIS Enterprise 11 0
  • ArcGIS Enterprise 11 1
  • ArcGIS Web Adaptor
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
