PROBLEM
Unable to batch divide polygons using the Divide tool in ArcGIS ModelBuilder
First Published: June 10, 2022
Last Published: June 25, 2026
In ArcGIS Pro, the Divide tool allows dividing a selected polygon into several features with a specified width or area. However, it is not possible to automate the Divide tool operation using ArcGIS ModelBuilder to batch divide polygons in ArcGIS Pro. The image below demonstrates a road layer consisting of multiple polygons on the map.
Multiple polygons in a layer of a project in ArcGIS Pro.
Cause
The Divide tool from the Modify Features pane is unavailable in the tool selection of ModelBuilder as only geoprocessing tools can be added to a geoprocessing model.
Solution or Workaround
If the operation only requires dividing the polygons into equal parts or areas, use the Subdivide Polygon tool to batch divide the polygons in ArcGIS Pro, as described in the steps below.
  1. In ArcGIS Pro, click the Analysis tab, and click Tools.
  2. In the Geoprocessing pane, search for and select the Subdivide Polygon (Data Management) tool via the Find Tools search box.
  3. In the Subdivide Polygon geoprocessing pane, select the polygon layer from the Input Features drop-down list.
  4. Specify a name for the new feature class in the Output Feature Class parameter.
  5. Select a division method from the Subdivision Method drop-down list. Depending on the method selected, configure the Number of Areas or Target Area parameter. Refer to ArcGIS Pro: Parameters for more information.
  6. Click Run.
The image below shows the output feature class after using the Subdivide Polygon tool to batch divide the polygons of the road layer in ArcGIS Pro.
The polygons are divided simultaneously using the Subdivide Polygon tool in ArcGIS Pro.
Article ID: 000027705
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
