PROBLEM
Unable to back up ArcGIS Enterprise that is federated with multiple ArcGIS Server sites
Last Published: June 7, 2023
When using the Web GIS Disaster Recovery (WebGISDR) tool to back up ArcGIS Enterprise that is federated with multiple ArcGIS Server sites in a multiple-machine deployment, the tool fails to back up the ArcGIS Data Store relational data store, and returns the following error message in the Command Prompt window:
Error:
Failed to back up the Relational ArcGIS Data Store:
Url: <ComponentAccessURL>.
Cannot access the file <BackUpFileLocation>.
The error in the Command Prompt window
Cause
The file path format of the backup location is specified as an absolute path in the webgisdr.properties file, restricting ArcGIS Server to only search the machine's drives for the location.
Solution or Workaround
Specify the file path format of the backup location as a UNC path in the webgisdr.properties file. The path below is an example of a UNC path:
\\myServer\data\datafiles
Refer to Microsoft: File path formats on Windows systems for more information.
Article ID: 000027773
Software:
  • ArcGIS Data Store
  • ArcGIS Server
  • ArcGIS Enterprise 10 9 x
  • ArcGIS Enterprise 11 0
  • ArcGIS Enterprise 11 1
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
