ERROR
Cannot access the file <Temporary File Path>
Last Published: October 13, 2023
Error Message
Attempts to run the webgisdr utility to create backup files for the ArcGIS Enterprise deployment fail, with the following error message returned in the Command Prompt window:
Error:
Cannot access the file <Temporary File Path>.
The error message returned when attempting to run the webgisdr utility
Cause
The ArcGIS Enterprise domain account and the account running the account running the WebGISDR tool does not have access to the backup folder specified in the BACKUP_LOCATION propery of the WebGISDR tool properties file when creating an ArcGIS Enterprise backup.
Solution or Workaround
Give the necessary accounts Full Control permissions to the BACKUP_LOCATION folder.
  1. Navigate to the BACKUP_LOCATION folder location and right-click the folder.
  2. Click Properties.
  3. Click the Sharing tab.
  4. Click Advanced Sharing….
  5. Check the Share this folder check box.
  6. Click Permissions.
  7. Select the account used to configure Portal for ArcGIS from the Group or user names list.
If the accounts are not listed in the Group or user names list, click Add..., and search for the accounts in the Enter the object names to select (examples) search box. Click Check Names, select the account under Matching names and click OK.
  1. Check the Allow option for Full control.
  2. Click OK.
The Permssions for Temp window used to give Full Control permissions to the accounts
  1. Repeat Steps 7 to 9 for the account running the webgisdr tool if a different account is used.
Article ID: 000024793
Software:
  • ArcGIS Data Store
  • Portal for ArcGIS
  • ArcGIS Server
  • ArcGIS Enterprise 10 9 x
  • ArcGIS Enterprise 11 0
  • ArcGIS Enterprise 11 1
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
