PROBLEM
Unable to authorize an ArcGIS Desktop license with an Esri Secure License File (ESLF)
First Published: December 21, 2020
Last Published: May 27, 2021
When attempting to authorize an ArcGIS Desktop license with an Esri Secure License File (ESLF), the license file fails to process, returning the following error message in the Software Authorization Wizard:
Error:
Authorization file has expired.
The Software Authorization Wizard returns the error message: Error: Authorization file has expired
Cause
The 'File Timeout Date' is set when generating the ESLF in My Esri. When a 'File Timeout Date' is set, the ESLF cannot be applied to a machine beyond the set date.
Solution or Workaround
To resolve the issue, generate or request a new ESLF. Refer to How To: Create an Esri Secure License File (ESLF) for the steps to do so. In Step 7 of the article, under 'Generating an ESLF', set the File Timeout Date to a later date, or leave the File Timeout Date field blank, as shown in the image below.
The File Timeout Date shows no entry during the process of generating a ESLF file
Article ID: 000024875
Software:
  • ArcMap
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
