PROBLEM
Unable to add items to the ArcGIS Online Content page
First Published: January 5, 2021
Last Published: January 5, 2021
On the ArcGIS Online Content page, users with sufficient privileges to create content can add items in supported formats for analysis and other organizational purposes. In some instances, the Add Item Image showing the Add Item button. button is not displayed when attempting to add content, or clicking the button does not render any results. When the button works, attempting to add items fails, and returns warning or error messages such as the ones described below.
Warning:
This service type is not supported.
Image showing a warning message that the service type is not supported.
Error:
This file type is not supported.
Image showing an error message that the file type is not supported.
Cause
  • The user has insufficient privileges to create content.
  • The user logged in to ArcGIS Online using a stored password in Google Chrome after a Chrome update.
  • The web item is added to the ArcGIS Online Content page using the wrong URL, or the web map is added using a URL.
  • The ArcGIS Online public or organizational account does not support the file type of the added items.
  • The ArcGIS Online organizational account subscription is not activated, or the credits required to store the content is insufficient.
Solution or Workaround
Depending on the cause, follow one of the methods below to resolve the issue.
Change the user role to enable content creation
Only administrators have sufficient privileges to change user roles.
Change the user role to a User or Publisher to enable privileges to create content.
The image below shows the Add Item button is displayed (for a user with sufficient privileges to create content).
Image showing the Add Item button in the ArcGIS Online Content page.
Log in to ArcGIS Online using the Guest or Incognito mode in Chrome, or a browser other than Chrome, or after removing the stored password in Chrome
  • Use the Guest or Incognito mode in Chrome to log in to ArcGIS Online.
  • Use a browser other than Chrome to log in to ArcGIS Online.
  • Remove all stored passwords in Chrome before logging in to ArcGIS Online.
Add the web item to the ArcGIS Online Content page using the correct URL
  • Add the web item to the ArcGIS Online Content page using the item's REST endpoint URL.
The image below displays an item's REST endpoint URL obtained from the bottom-right of the item's item details page in ArcGIS Online.
Image showing an item's REST endpoint URL.
Save the file in a supported format according to the ArcGIS Online account type, or upgrade the public account Activate the ArcGIS Online subscription, or purchase more credits
  • Activate the ArcGIS Online subscription to begin adding content.
  • Alternatively, contact Esri Support Service to obtain the subscription link to activate it.
  • Purchase additional credits from the Esri store to enable content storage.
Article ID: 000024597
Software:
  • ArcGIS Online
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
