PROBLEM
When adding a raster dataset such as a digital elevation model (DEM) or an Esri GRID to ArcMap or ArcGIS Pro, the following messages are returned respectively.
In ArcMap
In ArcMap, the error message is followed by a warning message.
Error: Invalid raster dataset. Failed to create raster layer.
Warning: Could not add the specified data object to the map. Failed to open raster dataset: <file path>: Permission denied
In ArcGIS Pro
Error: Failed to add data, unsupported data type. <file>
The following are known causes for this issue:
Depending on the cause, use one of the options below to resolve the issue.
In ArcMap
In ArcGIS Pro
Note: Alternatively, drag the folder from Windows File Explorer, and drop it in the Catalog pane in ArcGIS Pro.![]()
Remove spaces, special characters, or excessively long names from the file path and filename of the raster dataset stored in the local folder. Alternatively, store the raster dataset in a directory with a shorter path length. Refer to ArcGIS Pro: Output raster formats and names or ArcMap: Output raster formats and names for more information.
Before downloading the raster dataset, ensure the raster format is supported by ArcMap or ArcGIS Pro. Refer to ArcMap: Supported raster dataset file formats or ArcGIS Pro: Raster file formats for more information. After downloading the raster dataset, ensure all required auxiliary and supporting files associated with the raster dataset, such as .aux, .hdr, or world files (.tfw), are present in the same directory as the raster dataset. Avoid renaming individual raster files, as this can break the relationship between the raster dataset and its supporting files. If the raster dataset was previously renamed, ensure all related supporting files are renamed consistently or obtain a new copy of the dataset.
Delete the existing raster dataset from the local drive and redownload it from the original or authoritative data provider. Ensure the download is completed successfully without interruption. If the raster dataset is provided in a compressed format, such as .zip or .rar, extract all contents using a reliable extraction tool. After extraction, verify that all raster files and required supporting files are present, then add the newly downloaded raster dataset to ArcMap or ArcGIS Pro. Refer to ArcMap: Adding data to your map or ArcGIS Pro: Add data to a project for more information
Article ID: 000020632
Get help from ArcGIS experts
Start chatting now
