PROBLEM
The symbology of a file geodatabase exported from ArcGIS Online is not retained in ArcGIS Pro
Last Published: July 27, 2022
In ArcGIS Pro, the symbology of a file geodatabase is not retained when exported from ArcGIS Online. The image below shows the symbology in ArcGIS Online Map Viewer and ArcGIS Pro.
In ArcGIS Online Map Viewer
The web map displaying a tree-shaped point symbology in ArcGIS Online.
In ArcGIS Pro
The map view displayed the default point symbol in ArcGIS Pro.
This workflow applies to ArcGIS Pro 3.0 and above, and may or may not work in ArcGIS Pro 2.x due to changes to the UI. Refer to ArcGIS Pro: Migration from ArcGIS Pro 2.x to 3.0  for more information on the changes in ArcGIS Pro 3.0.
Cause
Symbology is a part of layer properties and can only be preserved in a map. Thus, when exporting the file geodatabase from ArcGIS Online to ArcGIS Pro, the ArcGIS Pro default symbology is displayed.
Solution or Workaround
Import and apply the symbology of the hosted feature layer
  1. Open the ArcGIS Pro project and log in to ArcGIS Online with privileges to edit features.
  2. In the Catalog pane, on the Portal tab, click My Content.
The Portal tab in the Catalog pane displaying contents from ArcGIS Online.
  1. Browse to and right-click the hosted feature layer. Click Add To Current Map.
  2. Import the symbology of the hosted feature layer and apply it to the exported feature layer. Refer to ArcGIS Pro: Import symbology to a feature layer for more information.
  3. Click OK.
The Import Symbology tool window to be configured.
Export the hosted feature layer as a feature class
  1. Launch ArcGIS Pro and log in to ArcGIS Online with privileges to edit features.
  1. Browse to and right-click the hosted feature layer. Click Add To New > Map.
  2. In the Contents pane, right-click the hosted feature layer added from ArcGIS Online, and click Data > Export Features.
  3. Configure the Export Features parameters as follows:
    1. Select the hosted feature layer from the Input Features drop-down list.
    2. Provide a name for Output Feature Class, and click Browse The Browse icon. to specify the location of the output feature class.
    3. Click OK. The output feature layer is automatically added to the map.
The Export Features tool window to be configured.
Optionally, save the symbology as a layer file in ArcGIS Pro. Refer to
How To: Save the symbology of a feature layer permanently in ArcGIS Pro  for more information.
The image below shows the symbology of the hosted feature layer retained in ArcGIS Pro.
The symbology of the feature layer in ArcGIS Pro identical with the symbology of the hosted feature layer in ArcGIS Online.
Article ID: 000028001
Software:
  • ArcGIS Pro 3 0
  • ArcGIS Pro 2 8 x
  • ArcGIS Pro 2 x
Get support with AI
Start chatting now
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
