PROBLEM
The Search widget does not return results from the hosted feature layer in ArcGIS Web AppBuilder
First Published: August 17, 2021
Last Published: August 17, 2021
The Search widget enables users to find locations and search features on the map using geocoding services or feature layers within the map. In some instances, when searching for an address using the search function, no results are returned if the search source is from a hosted feature layer.
The following image shows an example where no results are returned when searching for an address using the search function.
No results are returned after entering addresses in the search box in ArcGIS Web AppBuilder.
Cause
The issue occurs when the name of the original feature layer used has been changed, thus the service URL of the layer cannot be found.
Solution or Workaround
Follow the steps below to reconfigure the search source in the Configure Search window. Remove the original hosted feature layer from the search source, and re-add the new hosted feature layer.
  1. In ArcGIS Web AppBuilder, click the Widget tab.
  2. Click the Configure this widget icon on the Search widget.
Click the Configure this widget on the Search widget to set the Search widget configuration.
  1. In the Configure Search window, under Search source settings, click the Delete icon on the original hosted feature layer.
Delete the original feature layer from the Search source settings' list.
  1. Click Add search source to add the new hosted feature layer. Click OK.
  2. On the Widget tab, click Save to save the changes.
The following image shows the search results after the search source is reconfigured with the new hosted feature layer.
Results are returned after entering addresses in the search box in ArcGIS Web AppBuilder.
Article ID: 000026112
Software:
  • ArcGIS Web AppBuilder
Get support with AI
Start chatting now
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
