PROBLEM
The search box is unavailable in the Screening widget in ArcGIS Web AppBuilder
Last Published: July 14, 2021
The Screening widget allows users to define an area of interest using the Place Name tool, as it provides the ‘Search for a location’ search box to search for a location on the map. In ArcGIS Web AppBuilder, when attempting to use the ‘Search for a location’ search box in the Screening widget, the search box is not available, as shown in the image below.
The Screening widget displayed the Draw and Coordinates tools, where there is no search box available.
Cause
The Place Name tool in Area of Interest Tools is not enabled in the Screening widget configuration.
Solution or Workaround
In ArcGIS Web AppBuilder, check the Place Name tool check box in the Screening widget configuration to enable the tool and display the Search for a location search box.
  1. Log in to ArcGIS Online. Click Content > My Content.
  2. Browse to the ArcGIS Web AppBuilder web app, click More Options The More Options icon., and select Edit Application.
  3. In ArcGIS Web AppBuilder, on the Widget tab, browse to and hover over the Screening widget, and click Configure this widget The Configure this widget icon..
The Widget tab with several widgets listed including Screening.
  1. In the Configure Screening window, on the Analysis tab, browse to Area of Interest Tools, and check the Place Name check box.
  2. Click OK.
The Configure Screening window with several tools available and can be enabled by checking the checkbox Place Name and Coordinates. .
  1. Click Save to save the configurations.
The bottom of Widget tab showing the three options related with the web app, Launch, Previews and Save.
The image below shows the Search for a location search box is available in the Screening widget in ArcGIS Web AppBuilder.
The Screening widget displaying the Draw, Coordinates, and Place name tools where the 'Search for a location' search box is available.
Article ID: 000025760
Software:
  • ArcGIS Web AppBuilder
  • ArcGIS Online
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
