PROBLEM
The Portal Administrator Directory continuously prompts for login credentials
Last Published: March 24, 2023
When attempting to navigate around the Portal Administrator Directory, login credentials are prompted continuously, as shown in the following animation.
Unable to access the Portal Administrator Directory as it prompts for login credentials upon every click.
Cause
The Portal Administrator Directory is accessed using Internet Explorer. Portal for ArcGIS versions 10.9 and later do not support Internet Explorer.
Solution or Workaround
Access the Portal Administrator Directory using a supported web browser. Refer to ArcGIS Enterprise: Supported web browsers for more information.
The issue may be observed when accessing the Portal Administrator Directory in Microsoft Edge with the Internet Explorer mode enabled. In this case, disable the Internet Explorer mode in Microsoft Edge. Refer to Microsoft Edge: Configure IE mode policies for more information.
Article ID: 000028208
Software:
  • Portal for ArcGIS
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
