PROBLEM
The output raster pixel type is changed to a signed raster when running the Raster Calculator tool
First Published: September 17, 2019
In ArcGIS Pro, when using the Raster Calculator tool with an analysis mask (environment setting) and selecting signed and unsigned raster data as the inputs, the pixel type of the output raster is changed to signed. For example, when inserting a signed and an unsigned 8-bit raster data in the Map Algebra expression of the Raster Calculator tool and selecting an analysis mask, the output raster pixel type is fixed to a signed 8-bit raster. In some instances, the output raster displays gaps in certain areas.
Cause
This is a known issue. Refer to BUG-000124939 for more information.
Solution or Workaround
Use one of the following workarounds to solve this issue:
Convert the pixel type of the input raster data to unsigned
To obtain an unsigned raster data output, convert the pixel type of the signed raster inputs to unsigned before running the Raster Calculator tool. To do this, refer to the steps provided in ArcGIS Pro: Export or convert raster datasets. In the Export Raster pane, set the Pixel Type to unsigned. For example, select 8 Bit Unsigned to change an 8-bit signed raster to an 8-bit unsigned raster. Do this for each signed raster input.
An image of the Export Raster pane.
Use the built-in geoprocessing toolset instead of the Raster Calculator tool
This option requires a Spatial Analyst license.
Instead of using the Raster Calculator tool to build and execute Map Algebra expressions on the raster data, use geoprocessing tools such as the Is Null (Math toolset) and Con (Conditional toolset) tools to get the desired output raster. Refer to Spatial Analyst toolsets for more sets of spatial analysis and modeling tools for raster data.
Article ID: 000021824
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
