PROBLEM
The option to export an attribute table to a CSV file is unavailable in ArcGIS Web AppBuilder
Last Published: November 25, 2020
In ArcGIS Web AppBuilder, when attempting to export an attribute table to a CSV file, the ‘Export all to CSV’ or ‘Export selected to CSV’ option is unavailable.
The Export all to CSV or Export selected to CSV option is unavailable in the attribute table
Cause
This issue occurs when the option to export attribute tables to CSV files is not enabled in the Attribute Table widget.
When adding the Attribute Table widget to an ArcGIS Web AppBuilder app, the option to export attribute tables to CSV files is disabled by default.
Solution or Workaround
To resolve the issue, enable the option to allow exporting attribute tables to CSV files.
  1. Log in to ArcGIS Online, and click Content > My Content.
  2. Browse to the ArcGIS Web AppBuilder app, click More Options Image of the More Options icon, and select Edit Application.
  3. In ArcGIS Web AppBuilder, on the Widget tab, configure the Attribute Table widget.
  4. In the Configure Attribute Table window, check the Allow exporting to CSV check box, and click OK.
Image of the Configure Attribute Table window
The images below show the Export all to CSV or Export selected to CSV (when a record is selected) option is available in the attribute table in ArcGIS Web AppBuilder.
Image of the Export all to CSV option
Image of the Export selected to CSV option
Article ID: 000024527
Software:
  • ArcGIS Web AppBuilder
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
