PROBLEM
The locator source is displayed in the Map Layers widget when the Search widget is used in ArcGIS Experience Builder
First Published: June 19, 2025
Last Published: August 26, 2025
In ArcGIS Experience Builder, when searching for a location in the Search widget where the source interacts with a Map widget, the locator source is displayed in the Map Layers widget. This disrupts the user experience and creates challenges for end users.
The web experience below shows the locator source, ArcGIS World Geocoding Service, is displayed in the Map Layers widget when the Search widget is used in ArcGIS Experience Builder.
The locator source, ArcGIS World Geocoding Service is displayed in the Map Layers widget when searching using the Search widget in ArcGIS Experience Builder
Cause
  • In the Search panel, the 'Set as operational layers' check box is checked by default because the 'Records created' trigger runs the 'Show on map' action.
  • In the Map Layers panel, the 'Display layers generated at runtime' option is toggled on by default. This causes temporary layers, including locator source results, to be displayed even if they are not set as operational layers.
Solution or Workaround
Depending on the cause, the workarounds described below are applicable.
Uncheck the 'Set as operational layers' check box in the Search panel
  1. Open the ArcGIS Experience Builder web experience.
  2. Click the Search widget to open the Search panel.
  3. In the Search panel, on the Action tab, under Records created, click Show on map.
  4. Under Action settings, uncheck the Set as operational layers check box.
The Set as operational layers check box
  1. Save, preview, and publish the web app.
Toggle 'Display layers generated at runtime' off in the Map Layers panel
  2. Click the Map Layers widget to open the Map Layers panel.
  3. In the Map Layers panel, on the Content tab, under Source, select the layer. In this example, roadlink is selected.
  4. Under the selected layer, toggle Display layers generated at runtime off.
The Display layers generated at runtime setting
The web experience below shows the Map Layers widget displaying only the feature layers when the Search widget is used in ArcGIS Experience Builder.
The Map Layers widget displaying only the feature layers when searching using the Search widget in ArcGIS Experience Builder
Article ID: 000036345
Software:
  • ArcGIS Online
  • ArcGIS Enterprise
  • ArcGIS Experience Builder
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
