PROBLEM
The highlighted features are not cleared when using the ArcGIS Experience Builder Query widget
First Published: May 28, 2024
Last Published: May 31, 2024
When using the Query widget in ArcGIS Experience Builder, the query results are listed in the widget, and the features are highlighted in the Map widget when using the 'Show on map' data action. However, when attempting to clear the highlighted features, only the query results in the Query widget are cleared, while the features in the map remain highlighted, as shown in the image below.
The query results in the Query widget are cleared, while the features in the map remain highlighted
Cause
The 'Clear result' option in the Query widget is used instead of using the 'Clear result' option in the Map widget. Thus, only the features listed in the query search results are cleared and the highlighted features in the Map widget are retained and not cleared.
Solution or Workaround
To solve the issue, use the 'Clear results' in the Map widget to clear the highlighted features. In ArcGIS Experience Builder, on the canvas, in the Map widget, click Clear results and select the preferred query search results to clear the highlighted features.
The Clear results in the Map widget
The image below shows both the highlighted features in the map and from the query search results cleared in ArcGIS Experience Builder.
The highlighted features in the map and from the query search results cleared in ArcGIS Experience Builder
Article ID: 000032572
Software:
  • ArcGIS Experience Builder
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
