PROBLEM
In ArcGIS Pro, running the Grid Index Features tool generates an empty output and returns the following warning message:
Warning: WARNING 000117: Warning empty output generated.
The specified coordinates for the lower left origin of the output grid feature class are not within the extent of the input feature layer.
On the Grid Index Features pane, ensure the coordinates specified for the Polygon Grid Origin Coordinates parameter are within the extent of the input feature layer. To view the feature layer’s extent, navigate to the Source tab in the Layer Properties dialog box of the feature layer. Refer to ArcGIS Pro: Set layer properties for more information.
By default, the Grid Index Features tool generates a polygon grid within the input feature. If the coordinates specified for the Polygon Grid Origin Coordinate parameter are not within the extent of the input feature layer, uncheck the Generate Polygon Grid that intersects input feature layers or dataset option. This method enables users to customize the output grid feature to some extent on the map.
Article ID: 000031673
Get help from ArcGIS experts
Start chatting now
