HOW TO
Create a grid within an existing polygon feature grid in ArcGIS Pro
First Published: November 17, 2021
Last Published: January 5, 2022
Summary
In ArcGIS Pro, the Create Fishnet tool and the Generate Tessellation tool can be used to generate a new grid within an existing grid. However, the new grid generated from these tools does not line up if the existing polygon feature grid is rotated. The image below shows the new grid in red is not aligned with the rotation of the existing grid in black.
Map showing the new grid in red does not align with the rotation of the existing grid in black.
This article provides the workaround to generate a new grid that aligns with the rotation of the existing polygon feature grid using the Calculate Polygon Main Angle tool and the Subdivide Polygon tool.
Procedure
  1. Calculate the angle of the existing grid using the Calculate Polygon Main Angle tool.
    1. In ArcGIS Pro, in the Contents pane, right-click the polygon feature grid layer, and select Attribute Table.
    2. In the table view pane, click the Add Field button.
    3. Create a new column with the Double data type. In this example, the new field name is MainAngle.
A new field is added in the field view pane. The field name is MainAngle, and Double is selected as the data type.
  1. On the ArcGIS Pro ribbon, on the Fields tab, click Save.
  2. On the Analysis tab, click Tools.
Access the Geoprocessing pane by navigating to the Analysis tab on the ArcGIS Pro ribbon, and select Tools in the Geoprocessing group.
  1. In the Geoprocessing pane, type Calculate Polygon Main Angle in the search bar, and select Calculate Polygon Main Angle (Cartography Tools).
Type Calculate Polygon Main Angle in the Geoprocessing pane search bar, and select the first box in the results to open the Calculate Polygon Main Angle tool.
  1. In the Calculate Polygon Main Angle pane, for Input Features, click the drop-down arrow, and select the polygon feature grid layer. In this example, the layer is OriginalGrid.
  2. For Angle Field, click the drop-down arrow, and select the new field.
  3. Click Run. The main angle of the polygon feature grid layer, '2.32' is populated in the attribute table.
In the Calculate Polygon Main Angle tool, select the Input Features and Angle Field. Click Run at the bottom right corner of the pane to run the tool.
The table view pane shows that the result from running the Calculate Polygon Main Angle tool is populated in the MainAngle field.
  1. Generate a new grid using the Subdivide Polygon tool.
    1. In the Geoprocessing pane, type Subdivide Polygon in the search bar, and select Subdivide Polygon (Data Management Tools).
    2. In the Subdivide Polygon pane, for Input Features, click the drop-down arrow, and select the layer of the original polygon feature grid layer.
    3. For Output Feature Class, type the desired name. In this example, the name is NewGrid.
    4. For Number of Areas, type the desired value. In this example, the value is 4.
    5. For Split Angle, if the main angle calculated in Step 1(i) is a positive value, add an additional '-' symbol to make the value negative. In this example, the main angle is 2.32, so -2.32 is used.
If the main angle calculated is a negative value, remove the '-' symbol for Split Angle. For example, if the main angle is -5, use 5 as the value instead.
  1. Click Run. The new grid is generated in the NewGrid feature class.
In the Subdivide Polygon tool, select an option for Input Features and Output Feature Class. Type the desired value for Number of Areas. For Split Angle, type the main angle calculated. Click Run at the bottom right corner of the pane.
The map shows new horizontal lines are generated and the lines are aligned with the rotation of the existing grid.
  1. Split the new grid vertically.
    1. In the Subdivide Polygon pane, for Input Features, click the drop-down arrow, and select the feature class containing the new grid. In this example, the feature class is NewGrid.
    2. For Output Feature Class, type the desired name. In this example, the name is FinalGrid.
    3. For Split Angle, if the main angle calculated in Step 1(i) is a positive value, minus the value from 90. In this example, the main angle is '2.32', so '87.68' is used.
If the main angle is a negative value, remove the '-' symbol, and add the value to 90. For example, if the main angle is -5, use 95 as the value instead.
  1. Click Run.
  1. Refer to ArcGIS Pro: Modify basic symbol properties for the steps to customize the appearance of the final grid.
The image below shows the final grid generated is aligned with the rotation of the original polygon feature grid.
The map shows rectangular grid is generated based on the existing grid. The lines in the new grid align with the rotation of the existing grid.
Article ID: 000026834
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
