PROBLEM
The Export Data option is unavailable in ArcGIS Online
First Published: October 9, 2020
Last Published: October 9, 2020
In ArcGIS Online, when attempting to export a web layer to a file type using its item details page, the Export Data option is unavailable.
Image of the Export Data option is unavailable on the item details page
Cause
The following are known causes for this issue:
  • The member’s user type, default role, or custom role has insufficient privileges.
  • The option to export the layer to other formats is not enabled.
  • The layer is not published as a hosted feature layer.
Solution or Workaround
Depending on the cause, use one of the options below to resolve the issue.
Update the member’s user type, default role, or custom role to enable the privilege to create content
Only an organization's administrator can perform the following workflows.
Image of the Role privileges window
Enable the option to export the layer to other formats
  1. Sign in to ArcGIS Online. Click Content > My Content
  2. Browse to the hosted feature layer, click More Options Image of the More Options button, and select View item details
  3. On the item details page, click Settings, and click Feature Layer (hosted) on the top panel.
  4. Under Export Data, check the Allow others to export to different formats. check box.
Image of the Allow others to export to different formats check box
Publish the feature layer as a hosted feature layer in ArcGIS Online
  2. Browse to the feature layer, click More Options Image of the More Options button, and select View item details
  3. On the item details page, click Publish.
Image of the Publish button
  1. In the Publish window, add your title and tags to the Title and Tags fields, and click Publish.
Image of the Publish window
The image below shows the Export Data option is available on the web layer’s item details page.
Image of the Export Data button
Article ID: 000024291
Software:
  • ArcGIS Online
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
