PROBLEM
In some instances, when using the Disperse Markers tool in ArcMap, there is no drop-down button to select a layer in the 'Input Point Features With Marker Representations' field even though there are layers containing x,y events in the Table Of Contents pane.
The Disperse Marker tool does not support layers based on x,y event layers or x- and y-coordinates defined in a table as the input parameter. If the layer is added from a Microsoft Excel table or using the Make XY Event Layer tool, the layer does not appear in the drop-down list.
To resolve this issue, export the x,y event layer to a file geodatabase, and convert the symbology in the exported layer to representation.
Note: Click Yes in the dialog box to add the exported data to the map as a layer.![]()
After completing the steps above, the drop-down option to select the x,y event layers is now available in the Input Point Feature With Marker Representations field.
Article ID:000022052
Get help from ArcGIS experts
Download the Esri Support App
