PROBLEM
When attempting to calculate geometry for certain fields in an attribute table, the Calculate Geometry tool is disabled.
The selected field is an inherent field of the feature class managed by the geodatabase. For example, in a polygon feature class, there are four fields that are unavailable for editing: OBJECTID, Shape, SHAPE_LENGTH, and SHAPE_AREA.
When a new line feature class is created, an additional field is automatically created to record the length of the line. Likewise, when a new polygon feature class is created, two additional fields are automatically created to record the length (perimeter) and the area for each polygon feature. These are required fields and the properties cannot be modified.
To perform the Calculate Geometry operation, add a new field to the existing attribute table. The new field automatically records the properties of the feature. Use the following procedure to create a new field and use the Calculate Geometry tool:
Note: Ensure all previous editing is saved to enable the Add Field option in the Table Options drop-down list. In the Editor window, click the Editor drop-down, and click Save Edits.
Article ID: 000012524
Get help from ArcGIS experts
Start chatting now
