PROBLEM
The Attachments tab is unavailable in the Attributes pane in ArcGIS Pro
First Published: January 25, 2024
Last Published: March 5, 2026
When attempting to add an attachment to shapefiles or feature classes, the Attachments tab is not available in the Attributes pane.
The Attributes pane is displayed without the Attachments tab.
The Attributes pane without the Attachment tab
Cause
  • Attachments are not enabled on feature classes because this is the default setting.
  • Shapefiles do not support attachments.
Solution or Workaround
Enable attachments for the feature class
To make the Attachments tab available in the Attributes pane in ArcGIS Pro, enable attachments for the feature layer in ArcGIS Pro. Refer to ArcGIS Pro: Enable attachments for instructions.
Export the shapefile as a feature class and enable attachments
  1. In the Contents pane, right-click the desired shapefile and navigate to Data > Export Features.
  2. In the Export Features dialog box, specify the following parameters:
    1. For Input Features, select the feature layer from the drop-down menu.
    2. For Output Feature Class, specify a name for the feature class.
    3. Click OK.
  3. Enable attachments for the output feature class using the Enable Attachments tool. Refer to ArcGIS Pro: Enable attachments for instructions.
The Attributes pane displays the Attachments tab.
The Attributes pane with the Attachments tab
Article ID: 000031757
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
