PROBLEM
In ArcGIS Pro, when a feature layer is added to a map, feature templates are simultaneously listed in the Create Features pane based on the layer's current symbology displayed in the Contents pane. If the layer uses unique values symbology based on a subtype field, each template corresponds to a specific subtype or category. In some instances, changes made to symbology after the layer is added to the map are not reflected in the Create Features pane.
The image below shows the symbology in the Create Features pane does not match the symbology in the Contents pane.
The symbology in the Create Features pane and the symbology in the Contents pane do not match because of the following reasons:
Depending on the cause, use one of the workarounds below.
The image below shows the symbology list in the Contents and the Create Features pane match.
The image below shows the symbology in the Contents and the Create Features pane match.
Article ID: 000036290
Get help from ArcGIS experts
Start chatting now
