PROBLEM
Some tools in the Measure toolset are disabled in ArcGIS Pro
Last Published: June 12, 2024
In ArcGIS Pro, when attempting to measure the area or surface of a map, some tools in the Measure toolset in the Inquiry group are disabled, as shown in the image below.
The Measure toolset in the Inquiry group is disabled.
Cause
The Measure Direction Distance tool, Measure Offset tool, and Measure Angle tool are disabled because the map in an ArcGIS Pro project uses the geographic coordinate system (GCS). Refer to ArcGIS Pro: Coordinate systems, map projections, and transformations for more information. To identify the current coordinate system of the map, refer to ArcGIS Blog: Geographic vs Projected Coordinate Systems for more information. The Measure Vertical tool is disabled because the tool is only available in 3D scene instead of a 2D map.
Solution or Workaround
Enabling the Measure Direction Distance tool, Measure Offset tool, and Measure Angle tool
The map must be set to a projected coordinate system (PCS) to enable the Measure toolset in ArcGIS Pro. The workflow below demonstrates the steps to change the coordinate system of a map from geographic coordinate system (GCS) to projected coordinate system (PCS).
  1. Open the project in ArcGIS Pro.
  2. In the Contents pane, right-click Map and select Properties.
  3. In the Map Properties window, click the Coordinate Systems tab.
  4. Under XY Coordinate Systems Available, expand Projected Coordinate System and select the desired coordinate system based on the location zone. In this example, the projected coordinate system selected is WGS 1984 UTM Zone 54N.
The projected coordinate system selected is WGS 1984 UTM Zone 54N in the Map Properties.
  1. Click Apply > OK.
  2. On the ribbon, click the Map tab. In the Inquiry group, click the Measure drop-down menu to select the desired measure tool.
The image below shows the Measure toolset is enabled after changing the coordinate system of the map in ArcGIS Pro.
The Measure toolset is enabled after changing the coordinate system.
Enabling the Measure Vertical tool
Convert the map to a scene. Refer to ArcGIS Pro: Create a scene from the map for more information.
Article ID: 000032709
Software:
  • ArcGIS Pro 3 1
  • ArcGIS Pro 3 3
  • ArcGIS Pro 3 2
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
