PROBLEM
The Measure tool is disabled in ArcMap
First Published: May 5, 2016
Last Published: March 17, 2023
When accessing the Tools toolbar in ArcMap, the Measure tool is disabled.
The ArcMap toolbar displaying the disabled Measure tool icon.
Cause
This issue occurs because the map does not have known units.
The Data Frame Properties window displays the General tab with the Map parameter specified as Unknown Units in the Units section.
Solution or Workaround
Set the map unit of the data frame
Set the map unit of the data frame with a known unit such as Meters or Miles.
The Data Frame Properties window displaying the Map unit parameter in the Units section on the General tab.
The map units are determined by the data frame's coordinate system.
Specify a coordinate system
  1. Specify a coordinate system for the data frame.
The Data Frame Properties window displaying the Coordinate System tab with a list of coordinate systems. Click Apply, and click OK to specify a coordinate system.
  1. After the coordinate system of the data frame is specified, the map unit is also set with a known unit.
The data frame's coordinate system is usually determined by the first layer added to the map. Apply a projected coordinate system (PCS) to measure areas. Refer to ArcMap: Specifying a coordinate system for more information on changing and assigning a coordinate system.
Article ID: 000012430
Software:
  • ArcMap
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
