PROBLEM
Attempting to sign in to Portal for ArcGIS in ArcGIS Pro after Portal for ArcGIS upgrade returns the following security alert:
Warning:
The certificate you are viewing does not match the name of the site you are trying to view.
A secure connection with this site cannot be verified. Would you still like to proceed?
Warning:
The Certificate Issuer for this site is untrusted or unknown.
The security alert message may be returned due to several reasons but not limited to:
Depending on the cause, the workarounds provided are applicable.
Update the WebContextURL property to match the FQDN on the web adaptor port 443 binding. Refer to Portal for ArcGIS: Integrate your portal with a reverse proxy or load balancer for more information, and refer to the Set the WebContextURL property section for instructions.
If the FQDN between the portal hostname referenced in the signed SSL certificate subject Common Name (CN) or Subject Alternative Names (SANs) and the DNS lookup entries returned to the host when the upgrade occurred do not match, update the organization URL. Refer to Portal for ArcGIS: Update the organization URL for more information.
If the SSL certificate issuer is not recognized as trusted by ArcGIS Pro despite being listed in the Trusted Root Certification Authorities list, request a new certificate from a different certificate authority.
For expired certificate circumstances, generate a new self-signed certificate or request a CA-signed certificate renewal from the issuing certificate authority (CA) for the server. For example, refer to ArcGIS Server: Create a self-signed certificate. Next, import certificates into the Portal Administrator Directory. Refer to Portal for ArcGIS: Import a certificate into the portal for more information and instructions.
If the CA-signed server root certificate is not imported into Portal for ArcGIS, import the certificate into the Portal Administrator Directory as an Administrator of the organization. Refer to Portal for ArcGIS: Import the root CA certificate for more information and instructions.
Article ID: 000032827
Get help from ArcGIS experts
Start chatting now
