PROBLEM
Pictures display incorrect aspect ratios when added to layout in ArcGIS Pro
Last Published: November 28, 2024
In ArcGIS Pro, pictures added to the layout by dragging display incorrect aspect ratios within their bounding boxes, as shown in the map below.
Pictures added to the ArcGIS Pro layout display incorrect aspect ratio
Cause
This is by design. Dragging the pictures to position them distorts and does not preserve the pictures' aspect ratios within their bounding boxes.
Solution or Workaround
As a workaround, click a single point to add the picture in its original size and aspect ratio instead of dragging it.
  1. In ArcGIS Pro, open the layout view.
  2. Click the layout to add the picture.
  3. In the Element pane, click the Placement tab. Under Size, change the Width and Height of the picture element to the preferred size.
Uneven-shaped pictures such as circles and ovals contain spaces within the bounding boxes due to their aspect ratios.
The ArcGIS Pro layout shows the pictures added and each displaying the correct aspect ratios within their bounding boxes.
The ArcGIS Pro layout displays the correct aspect ratios for the pictures added
Article ID: 000034134
Software:
  • ArcGIS Pro 3 1
  • ArcGIS Pro 3 3
  • ArcGIS Pro 3 2
  • ArcGIS Pro 3 4
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
