PROBLEM
Unable to view images added from the Insert Picture dialog in ArcGIS Pro
Last Published: April 14, 2023
In ArcGIS Pro, images added to the layouts by double-clicking the images in the Insert Picture dialog box are not visible, as shown below.
The selected picture not being visible in the layout in ArcGIS Pro.
Cause
  • This is due to BUG-000151431 in ArcGIS Pro 3.0.
  • The ArcGIS Pro installation is not completed.
  • The ArcGIS Pro projects are corrupted.
Solution or Workaround
Depending on the cause, use one of the options below to resolve the issue.
Click only once when selecting the images in the Insert Picture dialog box
  1. In ArcGIS Pro, on the top ribbon, click the Insert tab.
  2. In the Graphics and Text gallery, click the Picture The Picture icon. icon.
  3. In the Insert Picture dialog box, search for the desired image and click the image once.
  4. Click OK and add the image to the layout.
The selected picture being able to be viewed in the layout in ArcGIS Pro.
Warning:
The instructions below include making changes to essential parts of the operating system. Esri recommends performing a backup of the operating system and files, including the registry, before proceeding.
Esri cannot guarantee results from incorrect modifications while following these instructions. Exercise caution. Consult a qualified computer systems professional if necessary.
Restart ArcGIS Pro
Close the current session of ArcGIS Pro, and restart the local machine.
Repair ArcGIS Pro
  1. On the local machine, type control panel in the search box on the taskbar. Select Control Panel.
  2. Click Programs > Programs and Features.
  3. Right-click ArcGIS Pro and select Repair. Select Change if Repair is not available.
The ArcGIS Pro Setup dialog box.
Use ArcGIS Pro 3.1
Alternatively, upgrade ArcGIS Pro to version 3.1 if necessary. Perform a clean uninstall by referring to Esri Australia Technical Blog: Performing a clean uninstall of ArcGIS Pro. After performing a clean uninstall, download and install ArcGIS Pro 3.1.
The image below shows the selected image is visible in the layout.
The selected picture being visible in the layout in ArcGIS Pro.
Article ID: 000029695
Software:
  • ArcGIS Pro 3 1
  • ArcGIS Pro 3 0
  • ArcGIS Pro 2 8 x
  • ArcGIS Pro 2 x
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
