PROBLEM
Paste Special returns null values in ArcGIS Pro
First Published: August 19, 2024
Last Published: July 30, 2026
In ArcGIS Pro, when using Paste Special, the attribute values are not copied to the destination feature layer's attribute table. Instead, the attribute table displays null values, as shown in the image below.
The null values in the attribute table of the destination layer
Cause
  • The source and destination feature classes have different schemas. ArcGIS Pro only transfers the field values from one feature class to another when the fields match.
  • The 'Keep source attribute values' option is not checked.
Solution or Workaround
Depending on the cause, the workarounds described below are applicable.
Modify or import the schema
Use the Fields view to compare the schemas of the source and destination feature classes. Then, modify the schema of the destination feature class to match the schema of the source feature class.
  1. Open the ArcGIS Pro project.
  2. Open the Fields view to compare the schemas of the source and destination feature classes.
  3. Modify the schema of the destination feature class to match the schema of the source feature class by performing one of the following workflows:
  4. Copy the features from a feature layer and use Paste Special to paste the features to another feature layer. Refer to ArcGIS Pro: Use Paste Special with the clipboard for instructions.
To transfer attributes between feature layers without altering the schema, use the Append tool. Refer to How To: Append feature classes that have different schemas in ArcGIS Pro for further instructions.
Keep the source attribute values when pasting the features
In the Paste Special dialog box, check the Keep source attribute values check box. This option pastes the attribute values into the corresponding fields of the destination layer. Refer to the first workaround to match the schemas of the source and destination layers.
The checked Keep source attribute values option in the Paste Special dialog box
Article ID: 000033264
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
