HOW TO
Change the data type of an existing field in ArcGIS Pro
First Published: April 23, 2020
Last Published: January 8, 2026
Summary
In ArcGIS Pro, when creating a feature class and table, a data type is selected for each field. Data types include number types, text types, date types, binary large objects (BLOBs), or globally unique identifiers (GUIDs). It is sometimes necessary to change the data type of certain fields after the table or feature class is created to manage data storage, facilitate analysis, and for data management.
Procedure
There are two options available to change the data type of an existing field in ArcGIS Pro. The first option is to create a new field with a desired data type, and to transfer attribute data from the existing field to the new field using the Calculate Field tool. The second option is to use the Feature Class To Feature Class tool to output a new feature class, including its respective attribute table and fields, with the desired data type.
Use the Calculate Field tool
Create a new field and populate it with the attribute data from an existing field using the Calculate Field tool. Use the workflow below to change the data type from Double to Float.
  1. In the Contents pane, right-click the feature layer, and click Attribute Table.
  2. In the attribute table, click Add The Add Field icon.. Create a new field with the desired data type in the feature layer attribute table.
    Refer to: ArcGIS Pro: Create a field and apply a domain and default value for instructions. In this example, the data type is Float.
  3. Open the Calculate Field tool.
  4. In the Input Table section, select the desired feature class. In this example, the feature class is SimpleBuildings, as shown in the image below.
  5. In the Field Name (Existing or New) section, select the field with the Float data type created in Step 1. In this example, the field is NewField.
  6. In the Expression section, under Fields, double-click the field with the attribute data to be transferred to NewField. In this example, the existing field with the Double data type is Shape_Area. The expression NewField = !<Shape_Area>! is populated.
  7. Click Run.
The attribute data from the field with Double data type is transferred to the new field with the Float data type.
Field data type is changed to float.
For example workflows to change data types from text to number and vice versa, refer to How To: Convert a string field to a numeric field.
Use the Export Features tool
Create a new feature class and attribute table with a new data type using the Export Features tool. Use the workflow below to change the data type from Long Integer to Short Integer.
  1. Open the Export Features tool.
  2. In the Parameters section, specify the desired feature class for Input Features. In this example, the feature class is Roads.
  3. Specify a name and location for the Output Feature Class. In this example, the name is FIPS26_Long_to_Short and its location is in the UpdatedRoads file geodatabase.
  4. Expand Fields, hover over the desired field with the Long Integer data type, and then click the blue pencil that appears besides that field to open the Field Properties dialog box. In this example, the field is FIPS26.
  1. In the Field Properties dialog box that opens, go to the Type dropdown, and select Short (16-bit integer).
  1. In the Field Properties dialog box, click OK to close out of that dialog box.
  2. In the Export Features tool, click Run.
The data type of the FIPS26 field is changed from Long Integer to Short Integer in the new feature class.
Article ID: 000023089
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
