PROBLEM
Option in the Update data window is disabled in ArcGIS Online
First Published: November 30, 2023
Last Published: February 26, 2024
In ArcGIS Online, when attempting to update data from the item details page of a hosted feature layer or hosted table, either the ‘Update features,’ ‘Add and update features,’ or ‘Overwrite entire feature layer’ option is disabled in the Update data window, as shown in the image below.
The Update data window.
Cause
  • The 'Update features,' 'Add and update features,' or ‘Overwrite entire feature layer’ option is disabled when synchronization or change tracking is enabled on the hosted feature layer. Features can only be added but not updated or overwritten when synchronization or change tracking is enabled.
  • The 'Overwrite entire feature layer' option is disabled when the hosted feature layer is published from ArcGIS Pro.
  • The 'Overwrite entire feature layer' option is disabled when the source item, such as a shapefile, file geodatabase, .csv file, or Microsoft Excel file, used to create the feature layer is deleted in ArcGIS Online.
  • The 'Overwrite entire feature layer' option is disabled for the sublayer of a hosted feature layer.
Solution or Workaround
Article ID: 000031600
Software:
  • ArcGIS Online
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
