PROBLEM
When data are added through the Add Data widget to an experience, they are not displayed in the Map widget, as demonstrated in the Map widget image below.
Depending on the cause, the workarounds below are applicable.
to open the Page panel.Note: Alternatively, in the Add Data widget on the published web experience, next to the added data, click Actions > Add to map.![]()
The Map widget image below shows the data added through the Add Data widget rendered and displayed.
To display the data stored in the .kmz file, unzip the .kmz file to extract .kml files. For example, refer to Microsoft: Zip and unzip files for instructions to unzip files in Microsoft Windows. After unzipping the file, upload the extracted .kml files to the File tab in the Add data window.
Article ID: 000033024
Get help from ArcGIS experts
Start chatting now
