PROBLEM
Tile layers are useful for displaying maps or layers on the web for displaying static data visualization. When a raster tile layer is published as a hosted tile layer to the ArcGIS Enterprise portal and ArcGIS Online, it appears pixelated when viewed in Map Viewer.
In ArcGIS Pro, create a custom tile layer based on the information from the input data source and publish it to the ArcGIS Enterprise portal or ArcGIS Online. Refer to How To: Publish a raster tile package with a different projection and custom scale as a hosted tile layer in ArcGIS Online for instructions. In the Generate Tile Cache Tiling Scheme pane, expand Advanced Options and select the preferred tile format from the Tile Format drop-down menu to match the map purpose while increasing the map resolution. Refer to ArcGIS Pro: Parameters for more information.
If the hosted tile layer is published from a hosted feature layer or a service definition file, update the tile cache by rebuilding it on the Settings tab in the layer’s item page. Refer to ArcGIS Enterprise: Manage raster tile layer settings or ArcGIS Online: Manage raster tile layer settings for instructions.
Article ID: 000035093
Get help from ArcGIS experts
Start chatting now
