PROBLEM
In some instances, features of a hosted web tile layer published from ArcGIS Pro disappear beyond a certain zoom extent or scale in ArcGIS Enterprise and ArcGIS Online Map Viewer, as shown in the example below.
The resampling property of the map service is disabled.
Note: The following workflows require administrator credentials to edit the map service.
Set the resampling property to true in the ArcGIS Server Administrator Directory. Refer to How To: Enable resampling for a map service in the ArcGIS Server Administrator Directory for instructions.
Set the resampling property to true in the ArcGIS REST Services Directory.
https://tiles.arcgis.com/tiles/<serverID>/arcgis/rest/admin/services/<name>/MapServer/edit
"resampling": true,
Note: The resampling property must be added above the exportTilesAllowed property in the Service Definition.
The features are now visible at high zoom levels in Map Viewer, as shown in the example below.
Article ID: 000031228
Get help from ArcGIS experts
Start chatting now
