PROBLEM
Hosted feature layer symbology from ArcGIS Pro is not retained in ArcGIS API for JavaScript 3.x apps
First Published: May 3, 2023
Last Published: January 15, 2026
The symbology of a hosted feature layer published from ArcGIS Pro displays correctly in ArcGIS Online Map Viewer, but is not retained in an ArcGIS Web AppBuilder web app. The images below show the layer in ArcGIS Pro, ArcGIS Online Map Viewer, and ArcGIS Web AppBuilder.
In ArcGIS Pro:
Different symbols color of the feature layer in ArcGIS Pro.
In ArcGIS Online Map Viewer:
Different symbols color of the hosted feature layer in ArcGIS Online Map Viewer.
In ArcGIS Web AppBuilder:
Simple point symbols of the hosted feature layer in ArcGIS Web AppBuilder.
Cause
Due to different ArcGIS API for JavaScript versions, symbology configured in ArcGIS Pro displays differently or is not retained in ArcGIS Web AppBuilder. ArcGIS Pro, Map Viewer, and newer apps, such as ArcGIS Experience Builder, use ArcGIS Maps SDK for JavaScript 4.x (formerly known as ArcGIS API for JavaScript), whereas older apps, such as Map Viewer Classic and ArcGIS Web AppBuilder, use ArcGIS API for JavaScript 3.x, which was retired in July 2024. Refer to ArcGIS Blog: ArcGIS Web AppBuilder Roadmap for Retirement for more information. Therefore, certain symbol properties available in ArcGIS Pro are not supported in ArcGIS Web AppBuilder.
Solution or Workaround
Share the map as a web map to ArcGIS Online with the 'Use symbol types compatible with all clients' option checked
In ArcGIS Pro, in the Share As Web Map pane, check the Use symbol types compatible with all clients check box, and share the map as a web map to retain and view its symbology in ArcGIS Web AppBuilder. Refer to ArcGIS Pro: Share a web map using a selected configuration for more information. Checking the Use symbol types compatible with all clients check box converts the symbology to a format compatible with both ArcGIS API for JavaScript 3.x and ArcGIS Maps SDK for JavaScript 4.x.
The Share As Web Map pane is to be configured.
Configure the symbology in ArcGIS Online Map Viewer Classic
In ArcGIS Online Map Viewer Classic, configure the symbology of the hosted feature layer to match the symbology in ArcGIS Pro. The symbology is retained and compatible with ArcGIS Web AppBuilder as ArcGIS Online Map Viewer Classic uses ArcGIS API for JavaScript 3.x. Refer to ArcGIS Online: Change Style reference (Map Viewer Classic) for more information.
Use compatible ArcGIS Online web apps to retain the hosted feature layer’s symbology
Create ArcGIS Online web apps that use ArcGIS Maps SDK for JavaScript 4.x, such as ArcGIS Experience Builder, ArcGIS Dashboards, and ArcGIS StoryMaps. Refer to ArcGIS Online: Create apps from maps for more information.
The image below shows the hosted feature layer’s symbology retained and displayed correctly in ArcGIS Web AppBuilder.
Different symbols color of the hosted feature layer in ArcGIS Web AppBuilder.
Article ID: 000030149
Software:
  • ArcGIS Web AppBuilder
  • ArcGIS Pro
  • ArcGIS Online
Get support with AI
Start chatting now
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
