PROBLEM
Feature points in a KMZ file do not display in Google Earth
First Published: February 5, 2021
Last Published: February 5, 2021
Feature points in a feature service exported as a KMZ file in ArcGIS Online do not display on Google Earth. However, the feature points are displayed as intended in ArcGIS Online and ArcGIS Pro.
Cause
The z-value of the feature points do not correspond to the surface of the map. For example, if the elevation of the maps surface is 100 meters, and the z-value of the corresponding point is 25 meters, the point does not display on the surface of the map in Google Earth.
Solution or Workaround
Change the z-values of the feature points in ArcGIS Pro to a value that corresponds to the elevation of the map's surface. Refer to ArcGIS Pro: Clear or edit z-values for steps to do this.
Article ID: 000024720
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
