PROBLEM
Failed to run the Map To KML tool in ArcGIS Pro
First Published: September 6, 2024
Last Published: September 6, 2024
In ArcGIS Pro, running the Map To KML tool fails even though all the parameters of the tool are configured, and the error message below is returned.
Error:
Fix the missing or invalid parameters: 1
An error message on the Map to KML pane in ArcGIS Pro.
Cause
The input map is added through the Input Map window using the Browse button, as shown in the following image.
List of web maps in the Input Map window.
This adds the item using the URL in the Map To KML tool. The Input Map parameter in the Map To KML tool does not recognize URL as an input thereby prompting the error.
The Map To KML tool pane is to be configured.
Solution or Workaround
To successfully run the tool, add the web map to the project as a map. In ArcGIS Pro, add the web map to the project, and in the Map To KML pane, select the map from the Input Map drop-down list.
Article ID: 000033225
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
