PROBLEM
"External sharing process failed" error when creating a mobile map package in ArcGIS Pro
First Published: March 5, 2020
When creating a mobile map package from the Share tab in ArcGIS Pro, the following error is returned:
Error:
Cause
If the data sources of the package are stored in network locations, access to these locations may be restricted by an antivirus software. This includes access to folders for sharing, such as staging, unpacking, project, and offline maps for ArcGIS Pro. Refer to ArcGIS Pro: Share and download options for more information.
Or, the size of the mobile map package is too large to be created through the Package Mobile Map pane from the Share tab.
Solution or Workaround
Before creating the mobile map package, ensure all data sources for the package are stored on the local machine, or access to them in the network locations are unrestricted.
Alternatively, use the Create Mobile Map Package geoprocessing tool to create the mobile map package. Refer to ArcGIS Pro: Create Mobile Map Package (Data Management) for more information.
Article ID: 000022697
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
