PROBLEM
Exported layout files do not match layouts in ArcGIS Pro
First Published: June 18, 2021
Last Published: June 18, 2021
When a layout is exported, the exported file does not display according to the layout settings in ArcGIS Pro. In some instances, the exported file has uneven page margins or the map frame and other layout elements are cropped.
The images below show layout settings in ArcGIS Pro and exported PDF files which do not match.
In ArcGIS Pro
Layout A and Layout B display two different layout templates in ArcGIS Pro.
In Adobe Acrobat Reader
The exported PDF files display different result from Layout A and Layout B in ArcGIS Pro.
Cause
Known causes of this issue include the following.
  • ArcGIS Pro only exports map frame and layout elements that are placed within the layout page. The map frame and layout elements in the exported file are cropped when placed outside of the layout’s page area.
  • The exported file displays an uneven page margin when the ‘Clip to graphics extent’ check box is checked.
Solution or Workaround
Use one of the following options to resolve the issue.
Place the map frame and layout elements within the layout’s page area
In ArcGIS Pro, drag and reposition the map frame and layout elements to place them within the layout page. Refer to ArcGIS Pro: Add and modify map frames and ArcGIS Pro: Work with layout elements for more information.
Alternatively, use ArcMap and check the Clip Output to Graphics Extent check box in the Export Map window, as in the image below, to export the layout with map elements that are outside of the layout page. Refer to ArcMap: Exporting your map for more information.
Check the Clip Output to Graphics Extent check box in ArcMap to export the map with map elements that exceed the page area.
Uncheck the 'Clip to graphics extent' check box to export the entire layout page
In ArcGIS Pro, uncheck the Clip to graphics extent check box in the Export Layout window to export the entire layout page, including blank areas. Refer to ArcGIS Pro: Export a layout for more information.
A layout can be exported at the page size or clipped to the extent of the elements on the page. Leave the Clip to graphics extent check box unchecked to export the entire page.
The image below shows the exported PDF files displaying the settings of Layout A and Layout B in ArcGIS Pro.
The exported results match with the layout in ArcGIS Pro after making necessary configurations.
Article ID: 000025826
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
