PROBLEM
Using the Buffer tool in ArcGIS Pro on a feature returns an empty output, and the '000117: Warning empty output generated' warning message is returned.
The following are possible causes:
Depending on the cause, use either one of the following solutions:
Specify an extent within the extent of the input feature in the Buffer pane
Specify a negative buffer distance within the minimum distance of the polygon feature
In the Buffer pane, for Distance [value or field], specify a negative buffer distance within the minimum distance of the polygon feature. This prevents null geometries from being created.
Article ID: 000023658
Get help from ArcGIS experts
Start chatting now
