PROBLEM
Converting a line feature to polygon returns an empty output in ArcGIS Pro
Last Published: October 7, 2020
In ArcGIS Pro, using the Feature to Polygon tool on a line feature returns an empty output, and the following warning message is returned:
Warning:
000117: Warning empty output generated
Image of Feature to Polygon tool error message
Cause
  • The line features have gaps between the lines.
  • When running the tool, the XY Tolerance value set by default, 0.001 meters, is too small.
Solution or Workaround
Depending on the cause, use one of the following solutions.
Identify the open ends of the line feature, and join the line
  1. On the Analysis tab, select Tools. Navigate to Data Management Tools > Features > Feature Vertices to Points.
  2. In the Feature Vertices to Points dialog box, specify the parameters as shown below.
    1. For Input Feature, select the line feature.
    2. For Output Feature Class, specify the file name and file directory.
    3. Set Point Type as Dangling Vertex.
    4. Click Run.
Image of Feature Vertices to Points geoprocessing tool
In the example below, there are lines joined like a closed polygon. However, after running the Feature Vertices to Points tool, all the lines have dots signifying each end of the dangling line. Zoom in to the points to see the gaps.
Image comparing the output after running the Feature Vertices to points tool
  1. Edit the line features based on the outcome of Step 2 to join the line features.
    1. Turn snapping on, and enable snapping agents. To do so, follow the instructions in ArcGIS Pro: Turn snapping on or off.
    2. On the Edit tab, select Modify. In the Modify Features pane, select Continue Feature tool. Join the hanging line feature vertex.
    3. Click Save.
  2. Run the Feature to Polygon tool.
Specify a greater XY Tolerance in the Feature to Polygon tool
  1. In the Feature to Polygon geoprocessing pane, specify the Parameters.
  2. Select the Environments tab. For XY Values, set the XY Tolerance value to be greater than 0.001 meters.
  3. Click Run.
The polygon shape is affected. The polygon is generalized based on the specified XY Tolerance values.
Article ID: 000023883
Software:
  • ArcGIS Pro 2 x
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
