PROBLEM
In ArcGIS Pro, when exporting data with coded value domains to a table or a feature class, the exported attribute table does not include the domain descriptions. Instead, it only displays the code values.
The image below shows the attribute table of the feature layer before exporting. In this example, the City, Level, District, and Type fields contain the domain descriptions.
The image below shows the attribute table with only the code values displayed after exporting to a table or a feature class.
This is expected behavior if the 'Transfer field domain descriptions' environment setting for exporting features is not enabled. ArcGIS Pro includes only domain code values when exporting a feature layer with coded value domains without the setting enabled.
Note: The following solutions do not work when exporting a table with coded domains in ArcGIS Experience Builder to a CSV file. This is a known issue, see BUG-000163188.
This workflow allows the selected feature layer to export the coded value domain descriptions by changing the environment setting.
to select a save location for the feature class.
This workflow allows all exported tables to display the coded value domain descriptions by changing the environment setting.
The image below shows the exported table with the domain description fields included when using the Transfer field domain descriptions environment.
Article ID: 000032226
Get help from ArcGIS experts
Start chatting now
