PROBLEM
Changing the map extent in Map Viewer does not display feature layers from ArcGIS Pro
First Published: September 4, 2024
Last Published: June 10, 2026
When changing the map extent of a feature layer published from ArcGIS Pro in ArcGIS Online Map Viewer, the feature layer is not displayed on the map and is disabled in the Layers pane, as shown below.
The feature layer is not displayed when the scale is outside the specified range in ArcGIS Online Map Viewer
Cause
The map extent is outside the specified range scales. The scale range visibility is enabled on the layer when the 'Show layer between these scales only' layer properties option is selected in ArcGIS Pro, and the maximum and minimum scales are specified. The layer is drawn only within the specified maximum and minimum scale limits when the scale range is enabled.
Solution or Workaround
Increase or decrease the maximum and minimum scale values in ArcGIS Pro
  1. In ArcGIS Pro, in the Contents pane, right-click the feature layer and click Properties to open the Layer Properties dialog box.
  2. On the General tab, under Visible Scale Range, select the Show layer between these scales only option.
  3. Specify the scale value in the Maximum scale property.
  4. Specify the scale value in the Minimum Scale property. Ensure all feature layers are displayed at the specified scale value.
  5. Click Apply > OK.
The Visible Scale Range settings in the Layer Properties dialog box
  1. Publish the layer to ArcGIS Online or overwrite the published feature layer to display the feature layer in ArcGIS Online Map Viewer.
Select the 'Show layer at all scales' option in ArcGIS Pro
  2. On the General tab, under Visible Scale Range, select the Show layer at all scales option.
  3. Click Apply > OK.
Set the visible range in ArcGIS Online Map Viewer
In ArcGIS Online Map Viewer, set the visible range for the feature layer to display at all scales. Refer to ArcGIS Online: Set the visible range for instructions.
Zoom to the full extent of the feature layer in ArcGIS Online Map Viewer
  1. In ArcGIS Online Map Viewer, on the Contents (dark) toolbar, in the Layers pane, browse to the layer and click Options The layer Options button in the Layers pane .
  2. Click Zoom to layer to display all features in the layer.
The Zoom to layer option
The map viewer below shows the feature layers displayed at full extent in ArcGIS Online Map Viewer.
The layer displayed correctly at all scales in ArcGIS Online Map Viewer
Article ID: 000033386
Software:
  • ArcGIS Pro
  • ArcGIS Online
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
