PROBLEM
In ArcGIS Pro, bookmarks allow maps to be saved at set positions or perspectives. This is useful for creating a bookmark map series, or for working on that specific extent at a later time. In some instances, selecting a bookmark in ArcGIS Pro does display it to the extent set when the Layout view is selected as the active view.
Use any of the following solutions depending on the cause.
Empty the cache by performing a soft reset
Note: The AppData folder is hidden by default. Refer to Microsoft: Show hidden files for steps to view hidden folders.
C:\Users\<Username>\AppData\Local\
Set the zoom extent on the map with a rotation angle that is a multiple of 45
The accepted values are 0, 45, 90, 135, 180, 225, 270, 315 and 360. Refer to How To: Rotate the map in ArcGIS Pro to set rotation angles on a map.
Article ID: 000025383
Get help from ArcGIS experts
Start chatting now
