PROBLEM
Basemap appears darker in ArcGIS Instant Apps
First Published: December 23, 2025
Last Published: December 23, 2025
In the ArcGIS Instant Apps Basic (Media Map) template, enabling the dark mode in theme configuration applies a dark interface and background, improving visual comfort in low-light environments. However, in some cases, when dark mode is enabled, the basemap appears darker, as demonstrated in the image below.
The basemap displays darkened in ArcGIS Instant Apps
Cause
Transparency is applied to the basemap in the Map Viewer web map. When dark mode is enabled in the ArcGIS Instant Apps web app, the dark background blends with the transparent basemap, causing the basemap to appear darker and reducing overall visibility.
Solution or Workaround
Change to light mode in the theme configuration
Use light mode to remove the dark background behind the basemap, preventing transparency from causing the basemap to appear darker. In the theme configuration, select Light from theĀ Select a mode drop-down menu. Refer to ArcGIS Blog: Instant Apps theming tools - It has never been easier to add color and branding to your apps for more information.
The basemap appears lighter when light mode is used in ArcGIS Instant Apps, as demonstrated below.
the basemap display lightened when using light mode in ArcGIS Instant Apps
Adjust the transparency of the basemap in ArcGIS Online Map Viewer
Set the Transparency slider to 0% to ensure the basemap is displayed at full opacity. This prevents the basemap from blending with the dark background in dark mode and eliminates the darker appearance. Refer to How To: Adjust the transparency of a basemap in ArcGIS Online (after June 2025 release) for instructions.
The basemap displays correctly in ArcGIS Instant Apps, as demonstrated below.
The basemap displayed correctly in ArcGIS Instant Apps
Article ID: 000039329
Software:
  • ArcGIS Online
  • Configurable Web Apps
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
