PROBLEM
Attachments are dropped when exporting a feature class from an enterprise geodatabase to a file geodatabase and vice versa
In some instances, attachments are dropped when a feature class is exported between geodatabases. A common scenario for this issue is when attempting to export a feature class with attachments from an enterprise geodatabase to a file geodatabase.
Cause
Export and import operations do not carry relationship class and related items along, resulting in drop of attachments.
Solution or Workaround
Copy and paste the feature class with attachments to the desired geodatabase. To transfer a feature class with attachments from a enterprise geodatabase (EGDB) to a file geodatabase (FGDB), follow the instructions provided below:
  1. Create a new feature dataset in the target FGDB using the spatial reference of one of the feature classes of the original enterprise geodatabase.
  2. Copy the required feature classes and paste it to the newly created feature dataset in the FGDB. The attachments are successfully copied.
The above given steps are in a scenario where the feature classes with attachments needs to be copied to a FGDB. The same workflow can be utilized when copying feature classes from a FGDB to another FGDB or from an EGDB to another EGDB.
Article ID:000017959
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
