PROBLEM
ArcGIS Pro fails to launch even though the service is running
First Published: May 11, 2023
Last Published: July 10, 2024
When attempting to open ArcGIS Pro after its installation, the application fails to open with the splash screen failing to display. However, when viewing the running tasks in Task Manager, the ArcGIS Pro process indicates that it is running in the background as usual.
Cause
The DigiCert Trusted Root G4 and VeriSign Universal Root Certification Authority certificates are not installed on the machine. This issue may occur when ArcGIS Pro is installed in certain environments, such as custom OS builds.
Solution or Workaround
If the ArcGIS Pro version is 3.0 and earlier, consider updating it to the latest version. If the issue persists, follow the workaround below.
Identify if the certificates are installed on the machine.
  1. Launch mmc. When prompted, click Yes.
  2. Click the File tab and select Add/Remove Snap-in....
  3. In the Add or Remove Snap-ins window, under Available snap-ins, click Certificates and click Add >.
  4. In the Certificates snap-in window, select Computer Account and click Next > Finish > OK.
  5. Under Console Root, expand Certificates (Local Computer) and expand Trusted Root Certification Authorities. Click Certificates.
  6. On the right menu, search for DigiCert Trusted Root G4 and VeriSign Universal Root Certification Authority.
If the DigiCert Trusted Root G4 and VeriSign Universal Root Certification Authority certificates are not available, contact the organization's IT team to install the certificates on the machine.
Article ID: 000030540
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
