PROBLEM
When attempting to access a web map from a Portal for ArcGIS organization in ArcGIS Collector, the web map does not display, preventing the viewing of the map.
Note: The functionalities of ArcGIS Collector, ArcGIS Explorer, and ArcGIS Tracker are now available in ArcGIS Field Maps. There are no new capabilities planned for these apps—all future updates will be focused on Field Maps. Migration is recommended. See ArcGIS Blog: Migrate to Field Maps for more information.
This issue occurs if the web map does not meet the conditions required to be displayed in ArcGIS Collector.
To view or edit a web map in Collector, the map owner must add and save at least one editable feature service to the map.
Note: When viewing an editable web map in ArcGIS Online, the Edit button displays above the Contents pane, as shown below.
Additionally, the feature service must reference the FeatureServer endpoint at REST to allow the web map to be accessible. A feature service has a FeatureServer endpoint if /FeatureServer is appended at the end of the feature service URL, as shown in the following example:
http(s)://ServerName.domain.com/arcgis/rest/services/FeatureServiceName/FeatureServer
For more information, refer to ArcGIS REST API: Appendix - Working with the Feature Server.
To allow the web map to display in ArcGIS Collector, the owner of the feature service must perform the following:
Note: When making changes to the services on the web map, owners are required to open the web map in Portal for ArcGIS, and save the web map to ensure the changes are saved.
Article ID: 000013297
Get help from ArcGIS experts
Download the Esri Support App
