PROBLEM
Android 4.2.0 device fails to connect to ArcGIS Online through Collector for ArcGIS
First Published: July 9, 2019
Last Published: August 6, 2025
The following documentation for Collector for ArcGIS (Android) states that Android 4.2 (Jellybean) is required to use the software:
Collector for ArcGIS (Classic): What are the requirements?
Some Android devices that are running versions 4.2, 4.3, and 4.4 may experience issues connecting to ArcGIS Online via Collector for ArcGIS.
Cause
This is due to the recent update to TLS 1.2 that has introduced new requirements for mobile devices accessing ArcGIS Online.
Solution or Workaround
If running a version of Android older than 5.0, and ArcGIS Online connectivity issues are encountered, confirm the Google Play Services version. The version must be 16.9.x or later to comply with the requirements of TLS 1.2.
Not all devices running Android 4.2, 4.3, or 4.4 experience this problem. Some Google Play Services update automatically while others require a manual update.
See also: Keep you services and apps working with Google Play Services:
Article ID: 000021079
Software:
  • ArcGIS Collector
  • ArcGIS Online
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
