PROBLEM
In ArcGIS Web AppBuilder, the Print widget is used to generate printable documents from a web application. The Print widget can be configured to use the ArcGIS Enterprise PrintingTools service, or a custom print service created in ArcGIS Pro.
In some instances, attempts to print the current map in the web app using the Print widget fail and return prompts for organizational login credentials.
The print service used when configuring the Print widget is not shared with everyone. Therefore, the Print widget on the publicly shared web app cannot be utilized by users outside the organization.
Enable the Everyone (public) option for the print service in ArcGIS Server Manager
Note: The following procedure may require the assistance of an IT personnel or members with administrator privileges.
<machine>.<domain>.com/<webadaptorname>/manager
Article ID: 000028663
Get help from ArcGIS experts
Start chatting now
